Finished most of the panel wiring but still need to tidy up/bundle the wiring.
Connected the transponder and checked that it powers on.
Ran wires aft for a radio speaker.
Ran wires aft for the pitch autopilot servo. It appears the servo will need to be mounted just aft of the rear spar and connected to the middle hole of the idler plate assembly F19-19.
Ran power to the 12VDC panel outlet through an inline ATM fuse holder. Fuse replacement will be from below the panel. I don't expect anything critical to be powered from the outlet, so if the fuse blows it will need to be replaced while on the ground.
Checked a satellite radio signal (headphone outlet jack) into the AUX jack of the radio. Plenty of volume and still good volume overide from aircraft broadcasts.
